Repair Common Kioti Mechanical Injection Pump Failure
   / Repair Common Kioti Mechanical Injection Pump Failure #101
Follow up to my second pump failure. Well it was a warm day so I pulled the fuel solenoid out and cut off the rod. Plugged it back in only so the wires don’t dangle into the fan. I installed the fuel shut off cable several years back so now I shut the key off then pull the fuel shut off cable. The fuel shut off hole is already in the dash and the cable fit right where it should have been and not that defective setup that was put in place for a few model years. No more rack slamming, tooth busting, rack jamming for me. The parts finder I used was Michigan Iron’s, so that’s the price from their website. I had to manufacture a couple of parts/pieces to make the cable work but hopefully I’ll never have to worry about a broken injector pump again.
   / Repair Common Kioti Mechanical Injection Pump Failure #102
Nice install bro!👍🏻☮️✌🏻
   / Repair Common Kioti Mechanical Injection Pump Failure #103
I thought I was the only one in the "failed twice" injector pump club. The 1st time I had a dealer fix it, but I believe they only fixed the one broken one which mine also let go in the off position and the second time it went (again in the off position) I replaced all 3 of the gears.
Concur. Once the IP is off the engine it's barely more difficult or expensive to replace them all (just put all parts back in the same cylinder). If the new gears are tougher that should provide many more years of service. Even if the new gears are no better that resets damage accumulation on the gears to "zero hours."
   / Repair Common Kioti Mechanical Injection Pump Failure #105
I think ridding your pump of that solenoid slamming is the only way to fully cure the teeth breaking.
2011 Wanco WLTC4 Towable Light Tower (A56857)
2011 Wanco WLTC4...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58216)
2012 TEX MEX...
