Renting post hole diggers?
/ Renting post hole diggers? #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I've got to dig 3 or 4 holes and figured I'd find a place that rented a 3pt mounted post hole digger. No such luck at all!
Do the rest of you guys have places around that will rent such equipment?
/ Renting post hole diggers? #2
As much as I hate to dig post holes by hand for just three or four holes that is what I would do.
/ Renting post hole diggers? #3
no place here to rent anything 3pt. unfortunately.
Although you probably could rent one of those counterbalanced one man PH diggers for what they'd want if they did rent the 3pt attachment.
/ Renting post hole diggers? #4
They do rent the two man hand held post hole diggers in our area. That's a lot better than digging by hand. Make sure your friend on the opposite of the two man digger is capable. Mine wasn't.
/ Renting post hole diggers? #5
I own a 3pt post hole digger, & will do 2-3 holes by hand instead of the work of hooking it up.... Never mind running out & finding one to rent.
That is about one of the easiest tools to abuse, I'd guess folks get tires of renting them out & coming back busted?
I'd have to drive 35 miles to find anyplace to rent any 3pt stuff, and small selection there I think. hope you find something.
--->Paul
/ Renting post hole diggers? #6
Just buy one. You know you want it. :D
/ Renting post hole diggers? #7
--->Paul
"this bolt here broke, and now it just spins...Good thing I got these grade 8 bolts in that size!"
If you are that apposed to digging 3 holes, just buy one yourself. There will be another hole to be dug later on.
/ Renting post hole diggers? #9
I can rent 3 point equipment, but it runs close to the same price to buy the implement at tractor supply. I have rented a post hole digger that is on a boom arm, attached to a gas engine, It worked great, and only takes one person. It looked like this, and worked great, I dug about 50 holes with it. I would see if anyone has one in your area. I rented it at an Ace rental place.
url
/ Renting post hole diggers? #10
url
Both Lowes and HD rent these in my area, as well as a local power equipment rental place. Maybe try Sunbelt Rentals and see if they have a dealer in your area.
/ Renting post hole diggers? #11
I rented a Bush Hog model 2102 from a local tractor dealer when I built my pole barn. It came with 18" auger, I had 14" concrete "pucks" for the poles to set on. Worked well. $125 for the weenkend.
/ Renting post hole diggers? #12
Our local rental places have them, but my experience with them isn't great. The ground here in the mountains is very rocky, and one rental had the cutting edge bent so much from hitting rocks that it didn't want to dig. The other hadn't been used in ages, and the PTO shaft was stuck so tight with old grease that it took me 20 minutes to free it so I could hook it up. Once that was done it worked great. Still, for 3 or 4 holes, it's a lot easier to do by hand than get the rental.
Terry
/ Renting post hole diggers? #13
For not that much more, rent a skidsteer with a PHD on the front. You have the ability to go forward or in reverse, and push down. Plus, positioning a skidsteer is a lot easier.
A buddy down the street lent me his two man PHD with his muscle for assistance. Got my two holes dug with him in no time.
I've bush-hogged his field before a couple of times so it will work out in the end.
UNUSED WOLVERINE QUICK COUPLER 4 (A64281)
UNUSED WOLVERINE...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2015 Dodge Journey SXT AWD SUV (A61574)
2015 Dodge Journey...
2015 Nisan Altima S Sedan (A61574)
2015 Nisan Altima...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
2022 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
