It seemed like it have a VERY difficult time pushing dirt around. I'm not too familiar with tractors but this just doesn't sound right.
Is this rental just a junker or is this how sub-compacts work? How does this compare to the B2501?
Did you have 4-WD engaged?
Tractors are engineered to PULL, not PUSH.
If you want to move dirt short distances you need a Box Blade mounted on the rear Three Point Hitch. PHOTO
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Heavier tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Kubota BX series and 'B' series tractors all weigh 1,700 to 1,800 pounds bare tractor.
The Kubota 'B' series has a three (3) range HST and larger wheels/tires, both of which transfer power to the ground better than the BX series. However, if you need more tractor 'grunt' consider a 2,700 pound bare tractor weight L2501/L3301/L3901. ((Your car or truck probably weighs around 2,700 pounds))
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
Selling a used tractor is easy. Selling multiple light implements in order to buy heavier, wider implements for a new, heavier tractor requires a lot of time. Depreciation on implements is generally greater than depreciation on a tractor.
When considering a tractor purchase, bare tractor weight first, tractor horsepower second and (narrowly) rear wheel
ballast third.
BUY ENOUGH TRACTOR
A quality dealer, reasonably close,
available for coaching, is important for tractor neophytes. Most new tractors are delivered with a glitch or two requiring correction. My kubota dealer is six miles away. I feel my local dealer continues to add value to my equipment after seven years. Dealer proximity is less important for those experienced with tractors and qualified to perform their own maintenance.
VIDEOS:
everything attachments videos - YouTube
