Removing water from small waterfall fountains
   / Removing water from small waterfall fountains #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I have a couple of small fountains that hold about 50 gallons of water each and have to be cleaned occasionally. At first I was using my wet/dry vacuum to suck out the water which was a pain to do. I recently discovered that a quicker and easier way is to use my leave blower to blow all the water out. It stirs up the water and removes all the grass, leaves and algae and I get each cleaned in less than 5 minutes without getting on my hands and knees or messing with dumping a 5 gallon vacuum full of water a dozen times or more since I also had to use a hose to wash everything out. With the leaf blower, just blow it clean and nothing else is needed.
   / Removing water from small waterfall fountains #2
Hey Gary,
Can you please tell me is these waterfall fountain portable?? & How much big it is??
The fountains can be moved but are very heavy. They have a 2" thick concrete lip around the pool which is plastic about 8" deep and 5 feet wide x 2 feet kinda clam shaped of water. The waterfall is 3 tiers high and of molded concrete also and the lip meshes into the water fall area. They were too heavy for me to lift by myself so I had my 2 part time gardeners set them in the ground.
I was removing the water with a shop vac and it took a long time to suck and dump the contents, plus had to hose water into it to clean up the algae. NOW with the leaf blower, I just blow it dry. All the blowing stirs up the water and pretty much cleans everything out as it blows the water and leaves out.
2018 Gehl R105 (A50123)
2018 Gehl R105...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
1994 Prevost Liberty Coach 40FT Class A Motorhome (A51694)
1994 Prevost...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
2018 Mac 48ft T/A Walking Floor Trailer (A51692)
2018 Mac 48ft T/A...
