removing track plates (grousers)
   / removing track plates (grousers) #1
tucker99
Hello, has nayone tackled the job of removing track plates from a set of hydraulic digger track chains and bolted them to new chains. I I guess an air wrench would be the go!
Russ.
   / removing track plates (grousers) #2
Russ theres a few ways to do this, I usually use an air ipact wrench and penetrateing oil to get the pads off of salvagable chains/rails. When i need to get the pads off a set of worn out rails Ill use the impact wrench but if they are stubborn i'll stop with that and use the torch. My new favorite toy is a gouging tip in my friends plasma cutter for the stubborn ones. I have taken them down and swapped them with a breaker bar but it takes too long. I change the pads out on a dozer last week in about 3 hours with some stubborn bolts. I had lots of oil and my impact wrench handy.
hey mate!.. I knew I was on the right track!.. thanks for the confident reply.
Check out
www.tucker.co.nz
my ship's home page.
Thanks again,
Russ
4 ft Plastic Feeder Trough (A53117)
4 ft Plastic...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2017 CATERPILLAR...
