removing track plates (grousers)
   / removing track plates (grousers) #1
tucker99
Hello, has nayone tackled the job of removing track plates from a set of hydraulic digger track chains and bolted them to new chains. I I guess an air wrench would be the go!
Russ.
   / removing track plates (grousers) #2
Russ theres a few ways to do this, I usually use an air ipact wrench and penetrateing oil to get the pads off of salvagable chains/rails. When i need to get the pads off a set of worn out rails Ill use the impact wrench but if they are stubborn i'll stop with that and use the torch. My new favorite toy is a gouging tip in my friends plasma cutter for the stubborn ones. I have taken them down and swapped them with a breaker bar but it takes too long. I change the pads out on a dozer last week in about 3 hours with some stubborn bolts. I had lots of oil and my impact wrench handy.
hey mate!.. I knew I was on the right track!.. thanks for the confident reply.
Check out
www.tucker.co.nz
my ship's home page.
Thanks again,
Russ
6 Pallets of Oil / Chemicals Absorbing Pads (A53117)
6 Pallets of Oil /...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
2015 TROXELL 130BBL VACUUM TRAILER (A53843)
2015 TROXELL...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
