Removing the steering ram from New Holland TD80D
   / Removing the steering ram from New Holland TD80D #1
NKWFresh
New Holland TD80D
Hi all,
My TD80D has a badly leaking power steering hydraulic ram. Due to our location it must be removed and taken away for repair.
Whats the process for removing the body end pin as it seems to be deeply embedded in the frame and I cant imagine that its a circlip.
Dave from Papua New Guinea.
   / Removing the steering ram from New Holland TD80D #2
Can you take a photo or two and post it?
Exploded Views are Great. Thanks R Neumann.
Ive just saved the URL.
Here are some pictures.
I have no issue with the Wheel side, thats just a circlip.
Im sorry the picture is not perfect but i need to know if there is a circlip on the inside, or, because there is a locking bolt on top, thats all there is and I can just bash it out!
David
David
R Neumann.
Attached snip from what you have sent me looks accurate.
If you have a look at part 12 it just looks like I could bash the pin out now that I have removed the locking bolt and washer.
Whilst the picture is upside down, part 12 looks like its only a washer.
   / Removing the steering ram from New Holland TD80D #8
It looks to me like 7 is a zerk grease fitting and if 9 and 10 (bolt and washer?) are removed the sleeve 11 should slide out. You may need to pry between the cylinder end and the axle housing to get 11 to move. Especially is it hasn’t had grease in a while.
I don’t understand part 12 unless it’s some type of cap.
   / Removing the steering ram from New Holland TD80D #9
Your photo 2 of 6 makes it look like the exploded view is upside down. That looks like part 11........?
It looks to me like the bolt on the wheel end, parts 4,5,6 need to come off. That may give you another option to remove part 11 and or the ram.
   / Removing the steering ram from New Holland TD80D #10
What are they calling #12. A little trick I use to get pins out is to use a air chisel with flat end.
12 in Large Excavator Bucket (A52377)
12 in Large...
2023 John Deere 324G Skid Steer (A53342)
2023 John Deere...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
LOT NUMBER 233 (A53084)
LOT NUMBER 233...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
