Removing sweet gum stumps
   / Removing sweet gum stumps #1
FarmerCharlie
Auburn, AL
JD 2130 and 1020
I need to remove about ten pretty big sweet gum stumps along a wet-weather ditch that empties into my pond. A friend dug out this double stump with his backhoe in about two hours http://i823.photobucket.com/albums/...rm/landscaping/StumpRemoval/IMG_5384_800w.jpg. The golf cart and 5 gallon bucket are for scale. It was the largest, and I'm guessing the root ball weighs some 5000 pounds.
I'm thinking about renting an excavator to finish the project, and would appreciate some advice. The local rental company has two machines: One is a Hitachi ZX135US 13 ton machine with a fairly narrow bucket for $700/day. The other is a Mustang ME8002 8 ton machine for $500/day.
Based on reading several threads here, I think either machine could do the job over a weekend rental. I'm not sure the smaller machine would be able to lift and drop the stumps to free the dirt for easier burning. The smaller width of the bucket on the larger machine seems to me like it would be better at breaking the roots with a minimal amount of digging. I do have a JD 2130 tractor with a FEL and box blade for cleaning up the site afterwards.
I would appreciate any opinions of folks who have done this. I have used Bobcat and IH mini excavators to dig holes for some large trees, but I think this project needs more muscle. Too bad I didn't think of this back when they were digging the pond. The contractor was pushing over trees like this with his Daewoo 300 like I push over privet with my grapple rake.
   / Removing sweet gum stumps #2
First, I hate sweetgums! Bain of my property. I would go with the larger machine since as you know they are tough stumps to get out. Does either have a thumb to make it easy to get out of hole? Of course, they will burn some fuel, so make sure you have enough on hand to keep working for the day.
First, I hate sweetgums! Bain of my property. I would go with the larger machine since as you know they are tough stumps to get out. Does either have a thumb to make it easy to get out of hole.
Both the machines do have a mechanical thumb, but I'm not sure the smaller machine could lift the root balls.
I have declared war on both sweet gum and privet. I can handle most of the privet myself, and the sweet gums are almost enough to justify buying a backhoe or excavator.
   / Removing sweet gum stumps #4
Have you thought about hiring someone to come out and grind them below the ground level? I have an older Komatsu PC220 that I've used to dig out a few very large sweetgum stumps. They go really deep into the ground and it took a big hole before I got the stump broke over. Basically, it was a huge mess. The larger machine you mention will dig the stumps out if that's the way you want to proceed.
I thought about hiring someone, but I enjoy this sort of work, and I need something to keep me out of trouble. :) I did get a quote from a stump grinder, and that would be a lot less money. But I need to do some grading and plowing to finish landscaping the area.
   / Removing sweet gum stumps #6
I would probably grind them below surface level. If they are anything like a black gum, they'll have a tap root clear to china.
   / Removing sweet gum stumps #7
I've taken out many sweet gum trees with my KX-91 mini (3.5 ton), many as big or larger as those pictured. The trick is to leave the tree intact, dig around it and push it over. (its recommended only to dig on 3 sides, leaving the side opposite where you plan to push from intact, that should keep the tree from falling on top of you) In practice I usually have to dig around all four sides, which is more risky. Watch for any existing lean and watch the wind direction, This time of year the tree is leafed out and the wind can take it from you. Push as high up as the machine can reach. Once its toppled over, I cut the stump off with a chainsaw. You'll won't have that luxury.
I've noticed that sweet gum roots have a tendency to grow out a little and then down which makes them harder to get to with the bucket. With a stump mostly likely they will all need to be cut before the stump will come out. Cut two sides then reposition the machines 90 degrees and cut the other two sides. You may be able to reach over and then under the stump to cut the tap root if it even has one, I have not seen much of a true tap root on sweet gums. Even a 13 ton machine may not be able to just rip stumps right from the ground.
If the machine won't pick it up, those machines you mentioned should pick it up,there are a couple things you can do. Using the bucket cut one edge of the hole like ramp and roll it out, once its out, or on its side in the hole start picking at the roots with the bucket, breaking up the roots and dirt clod to lighten it, and believe it or not starting filling the hole. When you start filling wiggle the stump around with the bucket, the loose dirt will work itself under the stump and it will slooooowly rise up.
Remember, the closer you keep the bucket to the machine, the more lifting force you will have, its all matter of leverage.
Let us know how it turns out.
   / Removing sweet gum stumps #8
Ok so someone please explain it to me... What's wrong with sweet gums? I know they tend to be messy, but I have one that I just love. It's about 40 feet tall and I'm guessing 20 or so years old.
   / Removing sweet gum stumps #9
Ok so someone please explain it to me... What's wrong with sweet gums? .
The balls thay produce.Bumper crop this year for me. I can't name anyone around here that like them. 1 a year till there all gone:thumbsup:
   / Removing sweet gum stumps #10
One sweet gum OK. I can handle a few spiky balls. Hundreds of trees like I had and still have - no way, in the late fall the ground is so littered with the balls you can not walk on it. Somehow they get everywhere too.
They are tough trees and pretty in the fall. We had the tail end of a F1 tornado come by our property this April, lost 40+ pines, the sweet gums were still standing.:confused2: The ground was saturated with water from weeks of rain and the sweet gums with their massive roots held fast and just bent in the wind, the pines jumped out and laid down.
2011 Chrysler 200 Convertible Coupe (A42744)
2011 Chrysler 200...
2007 KENWORTH T300 DATA VAN (A45333)
2007 KENWORTH T300...
Chery 6' 10 Drawer Workbench (Red) (A44502)
Chery 6' 10 Drawer...
2020 Chevrolet Equinox LS SUV (A42744)
2020 Chevrolet...
2020 DITCH WITCH WALK BEHIND TRENCHER (A45333)
2020 DITCH WITCH...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A42744)
2021 Ford F-150...
