Removing stuck stump jumper on brush hog
   / Removing stuck stump jumper on brush hog #1
greenmower
Kubota b7500
Hi, Long overdue, (june 2020)...While replacing the gear box on my brush hog I ran into a problem removing the stump jumper. It had seized with age to the shaft. Since I don't have a lot of tools for removing large things like this I had to cobble together something. Prying behind the stump jumper with split log pieces was not enough. What I learned actually worked well, over a 2 day try, (time is always your friend....was there for 20 plus years, can't expect to fall off in 20 minutes). I'll try to explain what I did so others may benefit. I took my tractor draw bar and clamped it
to the cutter blades, aligning the center hole of the draw bar over the center of the gear shaft. Then I put a large bolt with several washers and a nut on the end between the draw bar and shaft to work as a simple press. Tightening the nut pushes the draw bar out, the same as a press, however even with more washers added it would not release the stump jumper from the shaft. Hmmm...time is our friend so I sprayed it with WD-40 and let it set overnight. The next morning I tightened the nut another 1/2 turn, nothing...so out of frustration and knowing a bigger hammer sometimes helps....(you or the project?)....I thumped the end of the bolt one time with a sledge, not even very hard, and the stump jumper did just that...it jumped off the shaft. So...If you ever have a stuck stump jumper, try this method. It works.
end of bolt rounded with a grinder to seat into hole on shaft end.
Stand back, it literally jumped off the shaft...
Nearly complete, had to match Kubota orange...
   / Removing stuck stump jumper on brush hog #2
Thats is a common method with any type of press or pulling equipment.
Dont rely on just the sheer tension of the device.
I probably use this method most on 2 or 3 jaw pullers....and ball joint C-clamp things.
If it isnt going willingly....no sense in bending or breaking things or stripping/galling threads. Put an open end wrench on the puller so you can provide tension....then smack it with a hammer. Works 99.9% of the time. I have an aluminum hammer I like for this so I dont bugger up the hex on whatever puller I am using
   / Removing stuck stump jumper on brush hog #3
We always loosen the castle nut and put the cotter pin back in and go cut a little bit. It just falls loose.
   / Removing stuck stump jumper on brush hog #4
I just gotta say, that is pretty clever thinking. You get extra points for using what you've got on hand.
   / Removing stuck stump jumper on brush hog #5
Think I'd be adding steel skid shoes to the bottom leading edge on both sides as well.
   / Removing stuck stump jumper on brush hog #6
I always run a Bush Hog high in the front and let the tail wheel be my height. My skids only hit on uneven ground rarely.
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2018 UTILITY VS2RA...
202480 (A54757)
202480 (A54757)
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
