Removing Oil stains on asphalt driveway
   / Removing Oil stains on asphalt driveway #111
I have been reading this complete thread though I don't know why. Actually, I do. I am a retired small business owner and I wanted to see how this situation turned out. I wanted to see what other folks would do and did. It seems like the OP wants to make the customer completely whole. The OP wants to make it like it never happened. I would have done the same. In fact, I have done the same, though the business was different because I owned and operated a machine shop.
I have had to repair parts because things went wrong that were beyond my control. Sometimes things went wrong with a third party but since I was the original contractor I was responsible. Other times I goofed and scrapped a job. But I always strove to make the customer whole. This philosophy has certainly cost me money. It has also paid off in at least two ways. No customer has been able to say in good conscience that I shorted them in any way. Also, I have been able to sleep well at night. For me this a big deal.
If this way my driveway and the contractor made a genuine effort to clean up the spill I would have called it good. But that is my choice, not the contractor's choice. Stuff happens and everything can't be perfect. In fact, we had a new walkway poured and when the forms were pulled away part of the new walkway pulled away too. It was a small defect and the contractor said he would be out to fix the walkway. But the defect was very small and the concrete was dyed and the rest of the job was great, so we declined the repair. And we are all happy.
My point is that I would do everything to make the customer whole and would not expect the customer to want or ask for anything less. And this is exactly what the OP is doing. It is up to the customer to say that they would accept some accidental damage. Some folks posting here seem to be saying that the OP should expect the customer to expect less, to maybe expect that there might be damage done to their property. I commend the OP for thinking they should make the customer whole.
Having been in the paving business, first thing that comes to mind is a base like TSP or caustic soda.
Because TSP is hardly used now because it is a phosphate I completely forgot about it. But TSP is great at removing oil stains from stuff. Wear gloves though. I still use the stuff now and then to clean really greasy stuff. TSP is truly a great degreaser.
Eric
   / Removing Oil stains on asphalt driveway #112
Tide huh? Would have never thought that would be preferred over dawn
I used to use tide detergent powder on concrete as a youth because it had bleach in it would take the stain from used oil out. Sprinkle it on dry at the start of a drizzle rain, leave it on all night and if any was left in the morning just rinse it off and the stain was mostly gone.
   / Removing Oil stains on asphalt driveway #113
Eric
Nice to meet you. I look for businesses like yours. If I have a choice that's the only people I give my trade to, even if it costs me a little more.
   / Removing Oil stains on asphalt driveway #114
Hay Dude
Apparently you believe in the saying "You leave a site in 'as good as or better than condition' than it was when you arrived". It is something that I believe in and try to live by but in so many instances contractors (or power companies) don't. I take my hat off to you!!!! I wish you the best in resolving the problem. I have no suggestions for you. As several have suggested there are a number of BAD options presented here.
YES
   / Removing Oil stains on asphalt driveway #115
We use a steam pressure washer at work.
It does pretty well but our oil spots nowhere near your size.
The easiest but more expensive solution is what others have stated about re-sealing.
   / Removing Oil stains on asphalt driveway #116
On asphalt or are you talking about concrete? Or more correctly asphaltic concrete or Portland cement concrete?
   / Removing Oil stains on asphalt driveway #117
Go get a weed torch and burn the oils off.
When I got my garage coated with an epoxy coating, they took a torch and burned away all the oil. I know it's asphalt, but it's made using high temperatures to bind the bitumen.
2020 Hyundai Santa Fe (A56859)
2020 Hyundai Santa...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
Deere 325G (A57148)
Deere 325G (A57148)
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
Deere 35G (A53317)
Deere 35G (A53317)
PALLET OF HOLE SAWS (A58374)
PALLET OF HOLE...
