Removing lift arms on L3300
   / Removing lift arms on L3300 #1
jfay
Northeast MA
1996 Grand L3300, 1963 Farmall 140
I am trying to remove my three point hitch to install a subframe for a backhoe. The pins holding the lift arms to the tractor are impossible to remove. I don't think they have ever been removed before. Any tips or tricks to getting the pins out??
Thanks
Looking at my parts manual the lower arms on the three point are called lower links, not lift arms which are up above. Anyone have suggestions? Someone must have removed there three point hitch to put on a backhoe.
   / Removing lift arms on L3300 #3
Most draft arms just slip over a pin and are secured with a lynch pin. I wouldn't think you would have to remove the pin that the draft link slips over to install the backhoe. If you can post a pic of what you are trying to remove, that would help.
Sincerely, Dirt
   / Removing lift arms on L3300 #4
PB Blaster & a large hammer.
2011 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2011 INTERNATIONAL...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
