Removing lift arms on L3300
   / Removing lift arms on L3300 #1
jfay
Northeast MA
1996 Grand L3300, 1963 Farmall 140
I am trying to remove my three point hitch to install a subframe for a backhoe. The pins holding the lift arms to the tractor are impossible to remove. I don't think they have ever been removed before. Any tips or tricks to getting the pins out??
Looking at my parts manual the lower arms on the three point are called lower links, not lift arms which are up above. Anyone have suggestions? Someone must have removed there three point hitch to put on a backhoe.
   / Removing lift arms on L3300 #3
Most draft arms just slip over a pin and are secured with a lynch pin. I wouldn't think you would have to remove the pin that the draft link slips over to install the backhoe. If you can post a pic of what you are trying to remove, that would help.
Sincerely, Dirt
   / Removing lift arms on L3300 #4
PB Blaster & a large hammer.
2012 Ram 4500 Versalift TEL29N 29FT Bucket Truck (A50323)
2012 Ram 4500...
1996 Lincoln Town Car Signature Sedan (A50324)
1996 Lincoln Town...
Yanmar YM170D Tractor (A50514)
Yanmar YM170D...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
Case 1825 Skidsteer (Non Running) (A50515)
Case 1825...
Vermeer WR-20 8-Wheel Rake (A50774)
Vermeer WR-20...
