Removing large pins: Anyone use one of these???
   / Removing large pins: Anyone use one of these??? #1
Dougster
MA
2004 Mahindra 4110 w/509 BH
Anyone out there use one of these flat-head bits with their pneumatic, hand-held air hammer for removing large, stuck backhoe pins and similar:
Old Forge Tools 1981 - Pneumatic Hammer
Old Forge Tools OLD1981 Pneumatic Hammer - Toolfetch.com
Am I on the right track here? Or should I stick with the old sledge hammer and dowel method? :confused:
Or does someone have an even better approach??? :)
Dougster
   / Removing large pins: Anyone use one of these??? #2
What you really want is some kind of sideways arbor press. I suppose you could rig one up w/ a porta-power kit and some welding...
I'd love to know what the CAT etc. service trucks use. I'm 6' 240# & only have so many sledge swings in me before I loose "power".
To answer your question, I have used an air hammer to drive pins out. The attachment you show looks good in that it shouldn't damage the pin.
   / Removing large pins: Anyone use one of these??? #3
I have used an air hammer in many cases and they work ok. It's really stuck you might still need the big boy. :D
Good Luck,
Rob
   / Removing large pins: Anyone use one of these??? #4
Afternoon Doug,
I have used pneumatic tools before but not with that particular tool. I would think it would work well but Im still in the dark ages using a masonry hand held sledge and a 3/4" brass bar for beating on bolts and pins ! ;) You might try some of my favorite juice " Liquid Wrench" and possibly some heat also !
   / Removing large pins: Anyone use one of these??? #5
Doug,
This is what we use to drive drift pins, or bolts out of holes. They call it a B&O. One guy holds the B&O the other hits the end with a sledge hammer.
Ed
hazmat said:
What you really want is some kind of sideways arbor press. I suppose you could rig one up w/ a porta-power kit and some welding... I'd love to know what the CAT etc. service trucks use. I'm 6' 240# & only have so many sledge swings in me before I loose "power". To answer your question, I have used an air hammer to drive pins out. The attachment you show looks good in that it shouldn't damage the pin.
My emphasis added above.
I think your statement is right on the money. I would LOVE to stow-away in the Milton CAT repair facility with a camera and see what they use. You've got to know that it is NOT a big funky yellow sledge hammer!!! :D
Dougster
Good Luck,
Rob
The "big boy"??? :confused: I've got a Bosch Brute-style electric jack hammer... which actually works amazingly well by the way... but I've got no flat bit or guide or any other way to keep it centered on a pin working horizontally. ;)
Or did you just mean my sledge hammer??? :D
Dougster
scott_vt said:
Afternoon Doug, I have used pneumatic tools before but not with that particular tool. I would think it would work well but Im still in the dark ages using a masonry hand held sledge and a 3/4" brass bar for beating on bolts and pins ! ;) You might try some of my favorite juice "Liquid Wrench" and possibly some heat also !
Well, I certainly tried to loosen up some pins on the rockscape job... ;) ...but some are still holding on quite tightly!!! Liquid Wrench is very cool... but like Hazmat, there are only so many swings in me! And I am not 6', 240!!! I'm a lot closer to 5', 240!!! :eek:
Dougster
civesnedfield said:
Doug, This is what we use to drive drift pins, or bolts out of holes. They call it a B&O. One guy holds the B&O the other hits the end with a sledge hammer.
Ed
A very interesting tool Ed. I'd never seen one before in all my construction days. On the other hand, what does one do when there is no "other guy" around (preferably 6", 240) to do the hitting or holding??? :confused:
Dougster
   / Removing large pins: Anyone use one of these??? #10
Dougster
That's when you invite a friend over for a beer.:D After he has had a sip ask him to hold the B&O, make sure you tell him that it will only take a minute and it usually doesn't hurt. :eek:
SORKO MC19-10 LOT NUMBER 149 (A53084)
SORKO MC19-10 LOT...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
2017 Ford Expedition 4x4 EL XLT SUV (A51694)
2017 Ford...
8" & 10" I BEAMS UP TO 80" LONG (A51247)
8" & 10" I BEAMS...
