Backhoe Removing/Installing BK2375 - narrow shed
   / Removing/Installing BK2375 - narrow shed #11
Why would you have to drive over the bucket to hook up a backhoe? That just doesn't seem right. If backed into the storage shed and unhooked, then just back up to it to reattach, hook up the hoses to level and adjust, then back up, shove home the pins and go. YOUR backhoe must unhook very differently from mine.
He is saying that if the bucket cylinder leaks down (or the boom or DS, for that matter), which it will, then the front of the subframe lifts. To remount the BH, you have to back over the front of the sub-frame, which would be impossible if the front of the subframe is too high. I'm curious to find out how he did it. I'm guessing he had to back up next to the BH, close enough that he could hook the hydros up, reposition it, then disconnect and back over it properly.
I haven't had mine off for any extended period of time, but I found that overnight leak-down caused the front of my subframe to sink to the ground rather than lifting up. It may have something to do with the position that you rest your boom and dipperstick in. I would think that leak-down would cause your stabilizers to drop the rear of the subframe with time, but the direction the front of the subframe would move with leak-down in the boom and dipperstick would be harder to predict by eyeball. Of course, I'm not sure how it would act over time, though, since I haven't tried it.
   / Removing/Installing BK2375 - narrow shed #12
Hey, I think I can add something useful here. :laughing: Don't park the backhoe any closer to the rear wall than you absolutely have to. When you try to catch the frame and drop in the pins if there is any mistake you will push it into the wall and cause damage. Don't ask me how I know this.
This. Don't forget this advice.
I've moved mine as far as 2' trying to get the subframe to settle in the receivers.
   / Removing/Installing BK2375 - narrow shed #13
I guess I am spoiled with my B26 (only BH I have ever had). Subframe stays on the tractor as it is also part of the FEL. I only have to put down the stabilizers, get neutral pressure on two pins, pull them back then use the stabilizers to raise the backhoe up a bit, pull forward 18" or so, drop everything down till no more pressure on the hydraulics then unhook the two hoses from the back hoe, hooking the one on the tractor back in to form a closed loop. Finished, maybe 5 minutes start to finish. It does take a bit longer to get everything aligned and square when reattaching.
   / Removing/Installing BK2375 - narrow shed #14
That is basically the same procedure with the Kioti BH.
I think with any design, the point that connects to the tractor is going to shift when the BH is disconnected for an extended period of time. It's just a matter of getting the system re-pressurized, reset to the position you left it in, and then reconnecting.
   / Removing/Installing BK2375 - narrow shed #15
OP -
Is there anyway you can get a chain hoist over the BH?
A 1 ton chain hoist at HF is only about $40 after discount and then you can easily pick up the BH and spin it around.
... no need for chain hoists. Tried today and the BH comes off and goes on very easily. Not sure what I was worried about :)
Thanks everyone for the feedback!
Closing this post.
   / Removing/Installing BK2375 - narrow shed #17
I use a dolly to get the KB-2485 hoe positioned where I need it to be; the subframe, stabilizers and bucket then have nothing to do with dropping or raising anything over time, and the hoe can be moved fairly easily to line up to the tractor which is easier to do than line up the tractor with the hoe.
Install a loop with 2 male ends to connect the detented remotes when not using the hoe so you don't deadhead the circuit and kill the pump.
Only admin closes threads.
   / Removing/Installing BK2375 - narrow shed #18
I use a dolly to get the KB-2485 hoe positioned where I need it to be; the subframe, stabilizers and bucket then have nothing to do with dropping or raising anything over time...
Don't get me wrong, I think the dolly is a great idea, but how does it keep the subframe from shifting with time. Regardless if they are resting on the ground, or on a dolly, the cylinders that control that stabilizers, boom, dipperstick, and bucket will leak down with time and shift their position as well as that of the subframe. I have a feeling that there is a way to position the boom/DS/bucket so that the subframe just settles down as the cylinders leak down, but that position should be the same if it is on a dolly or on the ground.
   / Removing/Installing BK2375 - narrow shed #19
Glad you queried!:) Actually the subframe stays in place because the dolly supports the center of gravity of the entire unit. It is easy to keep the outriggers in place with their locks, and same with the boom & dipper. Mine has sat on the dolly almost a year with no issues whatsoever. It's ready to roll at a moments notice...
   / Removing/Installing BK2375 - narrow shed #20
I think if I had to remove the entire sub-frame to take off a backhoe, it would be either off or on all the time. Mine is easy to remove, but since I have 2 tractors, mine stays on all the time and ready to work at the turn of a key. It would be so easy to design all of them to remove via two pins rather than removing the frame so why do some require frame removal? Cheap/thoughtless engineering??
Deere 410L (A53317)
Deere 410L (A53317)
2007 FORD F-550 XL SUPER DUTY CHASSIS TRUCK (A58375)
2007 FORD F-550 XL...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2017 Mitsubishi Outlander SUV (A56859)
2017 Mitsubishi...
