Removing Gland Nut From Koyker FEL
   / Removing Gland Nut From Koyker FEL #1
ljplum12
Plano, TX
None
Any tips on removing the gland nut from a Koyker 140 lift cylinder?
Crescent has done nothing but tear it up.
   / Removing Gland Nut From Koyker FEL #3
does the tube have a small slot in it, if it does there is a wire in it that has to come out. if not make a box end wrench out of a piece of flat bar to were you can hit it with a hammer
   / Removing Gland Nut From Koyker FEL #4
I'm pretty sure that's a wire retained gland, it appears the access is on the right hand side of the barrel a little bit down in the picture.
   / Removing Gland Nut From Koyker FEL #5
Those pack of rats lock tite that gland nut,heat it up to at least 300 degrees,then gently tap it with a hammer 360 degrees around the thread base,then take the cylinder to a bench vice clamp it on the flats on the packing gland,not to tight it will egg shape,after securing the cylinder use a large pipe wrench on the end of cylinder or a long bar through the pin retaining end of the cylinder and have fun..! I had to mill those flats on my packing gland,I destroyed those flats on the packing gland..
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
HUSQVARNA CHAINSAW & BLOWER (A58374)
HUSQVARNA CHAINSAW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
