Removing gasket cement from inside of toilet tank - how?
   / Removing gasket cement from inside of toilet tank - how? #11
@newbury Any chance at all for removing the bolts bodily? Can you unscrew them at all?
Not to be critical, but "black sealant" is...a little indefinite, at least to me. If it were me, I would gently scrape off a chunk to get a better idea of what it might be before I got too far into things.
Pure guess: If it were mine, I would start by using a plastic scraper. I bought a kit of 6-8" long sturdy plastic scrapers in various small blade shapes for a few dollars when I had a big caulking job (flat roof, specialized caulk, and all of the caulk needed to come out). Depending on how the material behaves, I would do the following.
  • Dry all four tanks out.
  • If the material is hard and goes to pieces, like dry mud or mortar, I would suspect that it is old plumber's putty, and this is what I would expect to find on plumbing. If it is plumber's putty, that should soften up with heat (carefully!), or (OR!!!) organic solvents from mineral oil (slow) to naphtha, or acetone. I find it is usually just elbow grease as the material tends to fracture out pretty easily. Some people find hot water is enough to soften up plumber's putty for removal, but I haven't ever found it useful. Generally, plumber's putty starts soft and hardens with time, so old plumber's putty pretty well ignores heat in my experience. YMMV. It may leave a linseed oil stain in the porcelain, but that won't matter if you replace the old plumber's putty with new plumber's putty. If you want to switch to caulk, that's probably magic mix territory as the surface will need to be chemically free of the oil.
  • If the material shows any sign of being elastic, i.e. caulk, then spray the material with caulk remover, put a folded or rolled piece of paper towel down on the material and saturate the paper. Leave it for 24 hours, and try to scrape it out.
A dremel with a wire wheel or abrasive fluff ball helps to clean out the residue, but I find I go through both very quickly. Again, I would start with some sturdy plastic scrapers and by hand, without a hammer, see how far you get.
All the best,
Peter
   / Removing gasket cement from inside of toilet tank - how? #12
@newbury Random question/thought: how sure are you that the bolts are leaking, rather than being a cold point for condensation to drip off of?
It just seems odd to me that you have leaks on four toilets at about the same time.
All the best,
Peter
   / Removing gasket cement from inside of toilet tank - how? #13
All the best,
Peter
Interesting point on the multiple failures experienced at the same time.
Too bad the previous owner decided to do some non-standard plumbing and left a bunch of leaky tanks to fix. I know my heart would be really set on holding onto a 1970's avocado green bathroom suite if it matched my linoleum floors. Luxury vinyl just doesn't have the warmth of linoleum, especially the premium stuff made with asbestos.
   / Removing gasket cement from inside of toilet tank - how? #14
That's a classic! I don't know how you managed to part with it. 😱😆
All the best, Peter
   / Removing gasket cement from inside of toilet tank - how? #15
I would try some carb/choke spray, let it soak some/respray and try a plastic scraper - be sure not to get the choke spray on other plastic/rubber components. Brakleen is good for oily/greasy items but not so much on hardened caulks/putties. Brakleen is less harmful on MOST plastics/rubbers if you can use it though.
   / Removing gasket cement from inside of toilet tank - how? #16
Toto is one of the best brands of toilets out there because of how good they glaze them. Super, super smooth so nothing sticks to the bowl. I would never throw a Toto away, but I also hate paying for them!!!
Gasoline is known to soften sealants. I might also try some of the different acids that you can buy at the home stores just to see if you get a reaction. And you can get crazy trying paint removers and even wallpaper remover. I'd try anything that dissolves glue.
Everything has it's weakness. It's just a shame that you don't know what it is, that would make it a lot easier to figure out what to use.
   / Removing gasket cement from inside of toilet tank - how? #18
Don't know what your dealing with, but I've had good luck with brake parts cleaner. If your sure it's concrete, I'm not sure you'll find anything to dissolve it
That's why I was trying to do it with a solvent.
   / Removing gasket cement from inside of toilet tank - how? #20
Any luck?
2015 MACK CXU613 (A53843)
2015 MACK CXU613...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2022 BOBCAT T770 SKID STEER (A52705)
2022 BOBCAT T770...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
2013 Dragon Double Rail Roll Off Trailer (A53117)
2013 Dragon Double...
