Oil & Fuel Removing fuel tank on B7510
   / Removing fuel tank on B7510 #1
Trap
Northeast KS
Kubota B7610,
I must have some debris in my fuel tank. flow to filter was a trickle and tractor wouldn't run more than idle. I blew air from filter back to tank and flow rate was 100 time better. this tells me something is going on in the tank. So if any one has any good tips for removing the tank or other novel ideas about cleaning it out please pass them on. Thanks in advance. Tractor is a B7610, 4WD, hydro.
   / Removing fuel tank on B7510 #2
I replaced the tank on my old b7500. Not sure if similar, but I had to remove the hood and shroud near the dash. IIRC, I had to take the throttle handle off and loosen the plastic shroud that goes from the dash to floorboard so I could get at the blind final bolts holding the metal shroud that the hood hinges to. After that it was pretty straight forward.
Good luck, ymmv, but it took me a while.
J
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59575)
2018 INTERNATIONAL...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
1609 (A58375)
1609 (A58375)
2014 Audi Q5 AWD SUV (A56859)
2014 Audi Q5 AWD...
