I must have some debris in my fuel tank. flow to filter was a trickle and tractor wouldn't run more than idle. I blew air from filter back to tank and flow rate was 100 time better. this tells me something is going on in the tank. So if any one has any good tips for removing the tank or other novel ideas about cleaning it out please pass them on. Thanks in advance. Tractor is a B7610, 4WD, hydro.
I replaced the tank on my old b7500. Not sure if similar, but I had to remove the hood and shroud near the dash. IIRC, I had to take the throttle handle off and loosen the plastic shroud that goes from the dash to floorboard so I could get at the blind final bolts holding the metal shroud that the hood hinges to. After that it was pretty straight forward.
