Removing doors from cab on B3030
   / Removing doors from cab on B3030 #1
teeravis1
Central Wisconsin
JD 4044R
Does anyone know if you can remove the doors off the cab on the B3030, or if it is recommended that you don't. I'm thinking mowing lawn in summer it may be nice to have the doors off. I imagine it would be a bad idea to operate it with the doors open, I would think that would be to strenuous on the hinges.
   / Removing doors from cab on B3030 #2
I have to say I am sorry in advance for this responce, but I cant help how self amused I am by picturing this happening to someone, most likely myself.
I would find two trees about 6-7 feet apart and back up to them and stop.
now open both the doors.
try to relax as this next part can be noisey.
now step on the reverse pedal abruptly.
and there you have it, two doors nicely removed.
it is not going to be very easy to put back on using this method, but none the less this should remove them nicely.
   / Removing doors from cab on B3030 #3
ehchvac, That is not too funny, I have broke the right door into a million pcs before. (note to self) shut all doors after dismount at all times. a JD gator tail tail gate, It makes a BIG mess.
teeravis1, Since I have done this. Yes you can remove them, but I would not know why. Enclosed cab, heat and a/c no wind, dirt or dust in your eyes? That can not be beat in my book.
   / Removing doors from cab on B3030 #4
ehchvac, that thought would never work to remove the doors going in reverse because the doors open suicide :D
Good point 3 finger, I just laughed at the comment at the comment and dismissed it, but you are exactly right:D
   / Removing doors from cab on B3030 #6
C'mon guys, this isn't rocket science. If they're suicide doors, just drive forward through the trees.
   / Removing doors from cab on B3030 #7
Loan it to me, I'll come up with a way, even if I don't want to.
   / Removing doors from cab on B3030 #8
Why in the world would you want to remove the doors on a FACTORY CAB????
lawn_king,
The only reason I brought up maybe removing the doors would be for mowing the lawn in the summer. The cab is great, but I know there will be some nice cool evenings in the summer where it would be nice to be out in the evening breeze. However, when I am using it for other tasks or in the winter, I have no interest what so ever in removing the doors. I will happily stay out of the dust, weather, and the cold.
   / Removing doors from cab on B3030 #10
I have a B3030 HSDC, when i want to experience the cool breeze, i open the 3 rear windows and the roof vent.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A51039)
2022 MAXXD BD14...
3in Poly Pipe (A49461)
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
