Removing Detents? Possible?!?
   / Removing Detents? Possible?!? #1
znowybird
I have a ford 4610 with a loader. The loader is plumbed into the rear remotes. These both have detents. The previous owner used it for his silage loader and I am finding the detents to be extemely cumbersome for what i need the loader to do.
Can the detents be reduced or adjusted, perhaps removed? Didn't want to crack the remotes open without a little knowledge.
thanks,
adam
   / Removing Detents? Possible?!? #2
Warmonger....how dare you remove DETENTS!
   / Removing Detents? Possible?!? #3
While not familiar with your tractor, it is my experience that most detents can be removed.
Does it have a cylindrical shaped object on the opposite end of the valve to that which the lever moves.
If you can remove that cylinder (usually a couple small bolts) you should find the detent mechanism. Probably you'll need to remove a circlip first then slide off - very carefully the spring/s and collars (taking note of the order and orientation of the components).
I'd expect to find a small ball or pin and spring which will need to be removed.
Then re-assemble to a point where you can test the success or otherwise of your efforts!
   / Removing Detents? Possible?!? #4
Like Allenr said, if you have standard remotes.
If you have deluxe remotes, identified by large aluminum housings for the couplers, there is an adjusting screw with a lock nut along side the coupler. Try backing off the adjustment a couple of turns to disable the detent.
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
(6) Bags of Tire Chains (A51573)
(6) Bags of Tire...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
