Removing chicken wire from fenceposts
   / Removing chicken wire from fenceposts #11
As far as holding the removed staples, I used one of these 20 or 32 oz. plastic pop bottles with the big mouth. It keeps most of the staples in if ya knock it over. I also bent up a coat hanger into a hook, duct taped it to the bottle and then hook it to my belt. Saves having to bend over and prevents a kick over.
Mike
   / Removing chicken wire from fenceposts #12
I'd just like to say that I have new respect for chicken wire and chain-link hurricane fences.
When Susie and I bought our farm last January, there were 3 projects of old abandoned structures that seemed to be glued together with chicken wire. There was 1 other project that was 'welded' together with hurricane fence. All 4 coups and kennels needed to go. 20 years is past the life expectancy of coups and kennels - at least ones depending on wires for structural integrity.
The chicken wire on these 'buildings' was crossed, intertwined, tangled, twisted, nailed, tied, wired-together, and planted into the ground.
We tried to get the structures down fast by pushing down wood frames and wrapping the result into big globs of wire and wood. It wasn't lent to a fast process. The wire doesn't want to come off easily. It can't be pulled off by simply yanking here and there. And it cuts the living bejeebers out of arms or whatever other fleshy parts get in the way.
The ending mess does not compact well. We didn't need to recycle any of the material because it was very old, rusted, and the wood was rotting. But getting it into the trash bin was difficult and the wood/wire blob used a lot of wasted space due to the overall strength of the wire. Chicken wire also makes it so that wood sections don't fold over into neat units which are easy to toss into a bin.
For the last structure we hired a helper to do the removal. He simply cut to the chase and snipped off wire from wood. Great idea! The wood stacks neatly and the wire is a little more able to be compacted. Lesson learned: either a) hire someone who knows what s/he is doing, or b) cut the wire off first and deal with the resulting wood.
Hurricane fence is another story. The previous owner buried the chain links about 12" into the ground - hoping to save bunnies from Foxes. Over time the yard trees grew roots through those chain links.
NOTHING but NOTHING is able to pull out chain link fencing that is rooted into the ground.
Susan and I ended up cutting a few roots (the less-difficult method) and cutting many links, link by link, to get that fence out of the ground. Several feet of hurrican fence is still planted in that sacred ground waiting for a rototiller to have its tiller mangled some time in the future.
After we got the chain link fence out of the ground, now that we were totally exhausted and wanted to sell every square inch of our new farm, we were faced with what to do with a 700 pound roll of old rusted wire fencing.
A tractor! ... if we had one! /forums/images/graemlins/smile.gif Since we didn't have one, it came down to leverage or hiring someone 30 years younger and 30 years wiser. We went with the leverage idea because no 20-year-old-buff-farmhand was walking on our lonely country road at the moment, looking for fence demolition work. And if they would have been there at that precise moment, the part about 'wiser' would kick in pretty quick.
At the end of the day my advice is that Neosporin is good treatment for cut arms. Aspirin helps with backaches. Liberal application of alcohol is useful to rid those sore memories.
Good luck with your project.
Martin
   / Removing chicken wire from fenceposts #13
Great story! I had a similar situation but on a much smaller scale. Thank god no hurricane fence though!
Question: Why didn't you just push those blobs of wood and wire into a pile and throw some diesel on it followed by a match? At least in the end, you'd have a mass of metal to deal with and maybe some nails on the ground. /forums/images/graemlins/wink.gif
- Gerald
   / Removing chicken wire from fenceposts #14
California Central Coast is dry. Being a new farm owner, I'd hate to destroy some of the relationships with my neighbors over one little match!
Actually I'm not sure what the burn regulations are out there. And I didn't want to take any chances.
   / Removing chicken wire from fenceposts #15
The best tool I have found for getting those poultry staples out of posts is a large set of dikes. Grab onto as much of the staple as you can and twist. That should pull it out far enough that you can grab onto them with a pair of lineman pliars. Couple of seconds per staple with dikes followed by a little longer with the pliars and you have the staple in the bucket. I usually do all the staples in one area with the dikes before switching to the pliars. You can pull them all the way out with the dikes but sometimes the pressure required breaks the staple and you are stuck with multiple parts. I found it easier just to pull them far enough with the dikes to get the pliars onto them.
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
Case 580D (A47384)
Case 580D (A47384)
1999 24DTA pintle hitch trailer (A52128)
1999 24DTA pintle...
2019 GEHL RT105 SKID STEER (A51242)
2019 GEHL RT105...
