Removing buried electric lines
   / Removing buried electric lines
Thanks for the replies. They're aluminum, but big. I think I'll try to pull 'em out with the tractor, when the ground is wet (as much rain as we've had, that's every/any day - our ground is saturated). If they break, oh well...
   / Removing buried electric lines #12
Not sure of your setup but if it was me I'd be taking some precautions against whiplash if some came out and then it broke. But then again I don't know if aluminum stretches or not.
   / Removing buried electric lines #13
Even if you did pull it out. Aluminum wire isnt worth the effort to strip it for scrap.
   / Removing buried electric lines #14
I tried pulling some 10 gauge copper out of the ground that was direct buried. It kept breaking so I gave up.
   / Removing buried electric lines #15
A few years ago I worked for a trucking company that also did warehousing. They had an overflow, so leased a warehouse to handle it. Right after they moved it, somebody stole the 600 foot of copper entrance cable (8 conductors) so the company was on the hook for $12k to replace it. They replaced it and two weeks later it got stolen AGAIN! They cancelled the lease, moved the product elsewhere! Still had to pay for the second bunch of wiring!
David from jax
   / Removing buried electric lines #16
Thanks for the replies. They're aluminum.
Not sure of your length but sounds like it’s long enough it isn’t going to simply pull out.
You could try digging a hole down to the middle of the span, cut them in half there, then try pulling the half lengths, but even that might not work
   / Removing buried electric lines #17
If one knew approx location one might run a potato plow or a box blade with the rippers down to loosen things up????....maybe run a string line to stayin line with the cables as the tractor moves along???..........of course the string would have to be off set..........
Cheers,
Mike
   / Removing buried electric lines #18
When the electrician installed my new service lateral conductors, they just ran a trencher right over the old one and chopped it up in little pieces. Made quite a mess, that was 10 years ago and I'm still finding pieces of wire and insulation in the yard.
   / Removing buried electric lines #19
As others have stated, I doubt you will be able to pull it out. If you try, be aware you could damage other nearby underground structures, like pipes, or other underground cables. Was anything else placed in the trench when the line was installed?
If it were me, I'd cut the ends flush with the ground and be done with it.
There "should" be nothing else in the area. I have no idea how deep they put 'em. The loose ends are about 3 feet long and poking up next to the bin pad. I don't mow near them, but the weed whacker catches them once in a while - which is why they are now on my target list. I'll give pulling them a try, soon. Wood splitting is on the schedule today, before the heat comes in.
Pics and update to follow...
2000 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A49461)
2000 Ingersoll...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A51222)
2020 INTERNATIONAL...
2017 DRAGON 48' ROLL OFF TRAILER (A50854)
2017 DRAGON 48'...
2007 INTERNATIONAL SF625 BUCKET TRUCK (A50854)
2007 INTERNATIONAL...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
