removing Brush Hog blade bolts
   / removing Brush Hog blade bolts #1
ericm979
Super Member
Southern Oregon
Branson 3725H Deere 5105
Hi, I got the nuts off the blade bolts on my 6' Brush Hog with an air impact gun but could not get the bolts out of the blade carrier. I had a lot of penetrant, an engineers hammer and a length of pipe, and also tried an air hammer. I'm hoping to have another go at it with a propane torch (all I've got available) and a bigger hammer. Any other ideas or tips? Should I try heating the blade carrier though the access hole, or from below? I'll have it up on jack stands.
The blades are pretty worn so I think this unit got a lot of use and the bolts are probably original.
   / removing Brush Hog blade bolts #2
In my case, I took the whole assembly off the mower. Once the assembly was blocked up on the concrete floor I was able to whack the blade bolts properly with a sledgehammer to remove them. The bolt ends were chamfered well enough that I didn't have to grind anything off after beating on them.
Taking the assembly off of the shaft was accomplished by making a puller using a 20 ton jack.
   / removing Brush Hog blade bolts #3
Mine are tapered, keyed bolts. I set the stump jumper on blocks and beat it with a hammer from the top. I left the nut on most of the threads to avoid mushrooming the bolt head.
Without bracing the stump jumper, the first time I removed my blades, things just bounced and recoiled when I hit them with the hammer and the force didn’t act on the bolt.
   / removing Brush Hog blade bolts #4
I had a stuck PTO shaft that I tried lubricating with ATF/acetone. Seemed to take forever, but repeatedly using an air hammer to vibrate the assembly seemed to allow the fluid to penetrate the rust.
   / removing Brush Hog blade bolts #5
The blade bolts on my JD mmm were a PITA also. Had to drop the mmm and get really serious. Lots of penetrating oil and electric torque wrench.
Installed new blades & bolts. Used anti-seize on the bolts. Hope that helps next time.
   / removing Brush Hog blade bolts #6
Guess I was lucky. When I went to remove the blades off my 20+ year old mower (bought it new) the rattle gun removed the nuts easily. I threaded the nuts back on a few threads and gave them a tap with a claw hammer and the bolts popped right out.
   / removing Brush Hog blade bolts #7
Have 2 sets of blades for my Bushhog SQ600. Put sharpened set on in spring, sharpen dull set then swap out dull for sharp set in a year. Use anti-seize on bolts and threads. Have 3/4 battery impact, spins nuts right off. 2-3 whacks with a shop hammer and 1" bar of steel rounded on end as not to damage threads and bolts fall right out
   / removing Brush Hog blade bolts #8
You can beat till the cows come home and as long as the stump jumper is flexing you aren't getting a solid lick, take a bottle jack and put it under the stump jumper to stop it from moving when you hit the bolt, it should come right out after you do this.
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2012 International DuraStar 4300 Flatbed Truck (A55973)
2012 International...
More info coming soon! (A56859)
More info coming...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
2007 Yamaha Rhino 660 (A56435)
2007 Yamaha Rhino...
