Removing blades on Kioti RFM
   / Removing blades on Kioti RFM #1
SteveZ
Southern Illinois
Kioti CK20H
I have the 60" Kioti RFM. When removing/installing the blades, there is a flat machined on the spindle shaft to allow holding the shaft while loosening or tightening the blade nut. Does anybody know what size wrench fits this flat? I want to purchase an open end wrench to use for this, but I don't want to purchase an entire set..............Steve
   / Removing blades on Kioti RFM #2
Try a crescent wrench
   / Removing blades on Kioti RFM #3
Just go to a local auto supply or walmart or similar and buy a caliper to measure the head. They may also have some of the large plactic bolt measures that you can measure the head, and length.
John
   / Removing blades on Kioti RFM #4
I found the easiest way to remove the bolts is with an air impact wrench. Every other way was difficult to break them
loose.
I tried using a crescent wrench, but it's too wide (thick). When I tightened the blade nut, the wrench was also fastened in place.
I'll see if I can find some type of cheap gauge to measure it.
Steve
   / Removing blades on Kioti RFM #6
I can usually get by with just grabbing the blade with my hand and hitting the bolts with an airgun.
   / Removing blades on Kioti RFM #7
The crescent wrench is a gauge. Just measure the opening after applying it to the shaft.
   / Removing blades on Kioti RFM #8
All of my combination wrenches that look like they are close to the right size, are too thick.
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2016 JOHN DEERE...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2010 CATERPILLAR CM1210106 ROUGHT TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
Blue Diamond Quick Attach Brush Mower (A50514)
Blue Diamond Quick...
Land Honor Skid Steer Backhoe Arm Attachment (A50515)
Land Honor Skid...
