3-Point Hitch Removing Backhoe
   / Removing Backhoe #1
Kuboy
Kubota B7610
Hello,
I just got this 7610 and I would like to remove the backhoe. I purchased a manual but of course there is no info on the backhoe. The guy I purchased it from described it and it sounded easy but, of course who can remember all that stuff when your in the middle of negotiations?
Either way, if someone can forward a quick description or tell me where I can find diagrams that would help me greatly.
Thanks in advance
   / Removing Backhoe #2
Hello,
Thanks in advance
Can you post a picture of the mounting area of the BH...That might help for those of us not familiar with that exact model...
   / Removing Backhoe #4
Maybe this will help? It's not your tractor but my B2320 works the same, so maybe it will for you too!
[youtube_browser]SMyUg3m7ZUY[/youtube_browser]
   / Removing Backhoe
Nope, my hook up is different. No hydraulics to remove just pins on the bar under the seat and on the 3 point hitch.
   / Removing Backhoe #6
What runs the backhoe if no hydraulics?
   / Removing Backhoe #9
Kuboy,
You seem to have a 3PTH BH, so lower the stabilzers, lower and curl the bucket/boom, put some pressure on the bucket or stabilzers and remove the 3PTH arms, then with the bucket remove the center pin/arm under the seat.
Now the hydraulics, you must have two lines OR a pump on the PTO shaft. if two lines disconnect these lines, if PTO remove the pump from the pto by pushing in the pin and pulling the pump off the PTO splines.
If you posted some pics of your setup a more definitive answer reply is likely.
MAHINDRA EMAX 225 TRACTOR (A51243)
MAHINDRA EMAX 225...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
2013 Ford F-150 (A50323)
2013 Ford F-150...
Case IH 1250 Grinder Mixer (A50515)
Case IH 1250...
2010 Toyota Tundra (A50323)
2010 Toyota Tundra...
