Removing and insalling Gemtop Workmaster truck canopy
   / Removing and insalling Gemtop Workmaster truck canopy #1
altoonapillarrock
Altoona, WA
Kubota BX24
Is there a way I can use my BX24 to help with removing, storing, and reinstalling my canopy? I have an F350 and the canopy is all metal and quite heavy.
   / Removing and insalling Gemtop Workmaster truck canopy #2
Took me awhile to re-find this, might give you a place to start, whether in wood or metal.
Kubota - Rich's Woodshop
Scroll down about halfway, you'll see the pertinent ones -
Originally from this thread
http://www.tractorbynet.com/forums/customization/263694-homemade-quick-attach-14.html
Hope it helps... Steve
Wow! Awesome Jig. My cap is heavier that the one shown, but I am going to try it out. Thanks for taking the time to look this up. I will post the results in the spring.
   / Removing and insalling Gemtop Workmaster truck canopy #4
You're welcome - personally, "overkill" specialist that I am, I'd consider using square steel tubing to duplicate those pics - 1-1/2" .095" wall should be strong enough if you did a truss type approach. I would make two sides, with just a removable "criss-cross" horizontal brace between them to maintain spacing, then two up-facing pads per side with a large enough surface (padded with foam or ?) to avoid damage to the ceiling of the shell.
If you have enough space for storage, you could skip the "removable" part and just store it standing up on the end that attaches to the bucket... Steve
2016 Ford F-550 Service Truck (A53422)
2016 Ford F-550...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2025 K0608G UNUSED 3-Rail Style Fence (A53117)
2025 K0608G UNUSED...
2012 Nissan Maxima Sedan (A51694)
2012 Nissan Maxima...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
