Removing 48 BH from 3410. No extra parts though for 3PH???
   / Removing 48 BH from 3410. No extra parts though for 3PH??? #1
MAD MARK
I acquired a 4310 with a 48 backhoe. Was going to take it off so I got used to it on a nicer day and see how hard it is. After doing some reading on the internet I see that you are supposed to add some parts to be able to use the 3 point hitch.
Anyone know the exact parts I should be looking for when I go visit the original owner and look in his barn to be able to use the 3 point?
   / Removing 48 BH from 3410. No extra parts though for 3PH??? #3
I suggest you go to the seller to see if they have the 3PH components first.
I had a #48 backhoe on a Deere 4520. IIRC, you have to remove the draft (lower) links and the lifting links. These are not inexpensive items.
When you drop off the backhoe, make sure it's on a solid surface...I do not recommend setting it right on dirt as it'll likely sink (the 'hoe weighs about a thousand-1200 lbs.). I left my stabilizers up when it was dismounted.
Also, the 'hoe runs off the Power Beyond...read your manual to ensure you know what's required.
Good luck!
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
Wacker Neuson DT08 (A50123)
Wacker Neuson DT08...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2021 FORD TRANSIT 250 CARGO VAN (A53426)
2021 FORD TRANSIT...
NISSAN 80 PROPANE FORK LIFT (A53426)
NISSAN 80 PROPANE...
