Removing 48 BH from 3410. No extra parts though for 3PH???
   / Removing 48 BH from 3410. No extra parts though for 3PH??? #1
MAD MARK
I acquired a 4310 with a 48 backhoe. Was going to take it off so I got used to it on a nicer day and see how hard it is. After doing some reading on the internet I see that you are supposed to add some parts to be able to use the 3 point hitch.
Anyone know the exact parts I should be looking for when I go visit the original owner and look in his barn to be able to use the 3 point?
   / Removing 48 BH from 3410. No extra parts though for 3PH??? #3
I suggest you go to the seller to see if they have the 3PH components first.
I had a #48 backhoe on a Deere 4520. IIRC, you have to remove the draft (lower) links and the lifting links. These are not inexpensive items.
When you drop off the backhoe, make sure it's on a solid surface...I do not recommend setting it right on dirt as it'll likely sink (the 'hoe weighs about a thousand-1200 lbs.). I left my stabilizers up when it was dismounted.
Also, the 'hoe runs off the Power Beyond...read your manual to ensure you know what's required.
Good luck!
100 GAL FUEL TANK AND TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2025 Forklift Safety Basket Attachment (A51691)
2025 Forklift...
Ford 18in. Stock Rims (A53117)
Ford 18in. Stock...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
1989 14ft. Gamefisher Aluminum Jon Boat with Trailer (A51694)
1989 14ft...
2012 MACK GRANITE (A53843)
2012 MACK GRANITE...
