Removing 2 in pin from cyl
   / Removing 2 in pin from cyl #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
http://www.tractorbynet.com/forums/...-pt425-lift-arm-center-link-tilt-assembly.jpg
The roll over assembly on the right locked up the pin and roll over assembly. I have tried to push out the pin with a 20 ton shop press, but nothing happened.
What will happen if I apply a large amount of heat? Will both pieces expand? I could use a jet rod and jet out some of the pin, but do not want to ruin the larger roll over assembly.
Now, how about using something like CO2 to freeze the metal and therefore cause the metal to shrink. So, if I bore a hole through the 2 in pin, and jet the CO2 through the pin, will the pin shrink enough and allow the pin to be pushed out?
I have installed the other assembly for now with a new 2 in pin, but would like to have the other roll over assembly for future use.
What have some of you done in a similar situation?
Any good ideas are welcome.
   / Removing 2 in pin from cyl #2
JJ,
I would try to heat the outer surface first, then put it on the press.
E/S
   / Removing 2 in pin from cyl #3
When I have pins like this stuck, I put it in the press with all the pressure I can apply and then start heating. When it breaks loose the press will jump and there will be a loud bang.
Bill
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
2022 Club Car...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2013 Ford Edge SE SUV (A50860)
2013 Ford Edge SE...
Komatsu PC138 (A50490)
12.7 LITER DETROIT GENERATOR SKID (A50854)
12.7 LITER DETROIT...
