Removing 2 in pin from cyl
   / Removing 2 in pin from cyl #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
http://www.tractorbynet.com/forums/...-pt425-lift-arm-center-link-tilt-assembly.jpg
The roll over assembly on the right locked up the pin and roll over assembly. I have tried to push out the pin with a 20 ton shop press, but nothing happened.
What will happen if I apply a large amount of heat? Will both pieces expand? I could use a jet rod and jet out some of the pin, but do not want to ruin the larger roll over assembly.
Now, how about using something like CO2 to freeze the metal and therefore cause the metal to shrink. So, if I bore a hole through the 2 in pin, and jet the CO2 through the pin, will the pin shrink enough and allow the pin to be pushed out?
I have installed the other assembly for now with a new 2 in pin, but would like to have the other roll over assembly for future use.
What have some of you done in a similar situation?
Any good ideas are welcome.
   / Removing 2 in pin from cyl #2
JJ,
I would try to heat the outer surface first, then put it on the press.
E/S
   / Removing 2 in pin from cyl #3
When I have pins like this stuck, I put it in the press with all the pressure I can apply and then start heating. When it breaks loose the press will jump and there will be a loud bang.
Bill
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2020 John Deere 9470R Tractor (A50860)
2020 John Deere...
Wooden Desk And Shelf (A48083)
Wooden Desk And...
Pallet Fees (A50774)
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
