Ballast Remove tire ballast
   / Remove tire ballast #11
I'd shoot it with a .22.
JayC
12 guage/punkin ball is quicker:laughing::laughing:
But in all honesty, there is no real reason to remove the fluid unless the tires are worn out, or you need to repair one.
If you are removing the fluid "because some one said you probably don't need it"...........you won't like what happens afterwards.
   / Remove tire ballast #12
Say what?
I think op is asking how to remove liquid in filled tires?
DevilDog
I was saying that I'm not sure how to remove the ballast, and that if he was using the backhoe he should not have ballast in the tires in the first place.
   / Remove tire ballast #13
Why should there not be ballest in the tires to use the backhoe???
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55315)
2023 New Holland...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2006 Gehl RS5-34 6,000lb 4x4 Rough Terrain Telehandler (A55851)
2006 Gehl RS5-34...
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
2011 Ford Edge AWD SUV (A56859)
2011 Ford Edge AWD...
40' CONTAINER (A57192)
