remove pto solenoid on a 425
   / remove pto solenoid on a 425 #2
The armature comes off after you remove the nut and plastic washer. The nut should be torqued to 195 inch lbs. when it goes back together.
If you need to remove the guts of the valve JD calls for a special socket. I have not needed to remove mine so I can't provide any additional insight on the process.
This proceedure, as well as the rest of your 425 service proceedures are covered in a TM-517 Technical Manual. It's worth the money if you plan on other projects.
   / remove pto solenoid on a 425 #3
:welcome:
piper, did that answer your question?
atschirner
My tech manual is TM1517, but that is the CD (and agree, well worth the money)
   / remove pto solenoid on a 425 #4
Thanks Beenthere,
I was reading the publication number off my computer screen. Thanks for the clairification for others.
Best, AT
   / remove pto solenoid on a 425 #5
My pto does NOT disengage. Is the solenoid the probable cause?
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2013 FREIGHTLINER...
TORO TR20 WALK BEHIND TRENCHER (A51406)
TORO TR20 WALK...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
