remove pto solenoid on a 425
   / remove pto solenoid on a 425 #2
The armature comes off after you remove the nut and plastic washer. The nut should be torqued to 195 inch lbs. when it goes back together.
If you need to remove the guts of the valve JD calls for a special socket. I have not needed to remove mine so I can't provide any additional insight on the process.
This proceedure, as well as the rest of your 425 service proceedures are covered in a TM-517 Technical Manual. It's worth the money if you plan on other projects.
   / remove pto solenoid on a 425 #3
:welcome:
piper, did that answer your question?
atschirner
My tech manual is TM1517, but that is the CD (and agree, well worth the money)
   / remove pto solenoid on a 425 #4
Thanks Beenthere,
I was reading the publication number off my computer screen. Thanks for the clairification for others.
Best, AT
   / remove pto solenoid on a 425 #5
My pto does NOT disengage. Is the solenoid the probable cause?
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
1268 (A50490)
1268 (A50490)
