Remove LT1050 steering sector
   / Remove LT1050 steering sector #1
JRobyn
Elite Member
Middle TN
Kubota L4330HST
Hi guys,
Anyone successfully removed the steering sector on a LT1050? Is it possible to do without pulling out the whole pedal mounting plate? I can't see a good way to get to the sector mounting nuts on the top of the plate. I'm trying to replace the tie rod end bushings and the nut is just spinning on the bolt, so either the nut or bolt is stripped. I might get lucky and cut the nut off and still have a usable bolt, but I am probably NOT that lucky!
- Jay
   / Remove LT1050 steering sector #2
info in attachment may help...
  • STRG GEAR_PINION REPL section35.pdf
Wow! Thanks rcbe! That is EXACTLY what was needed. And as I suspected, the drag link pivot bolt is stripped so the sector WILL need to be replaced. Evidently you have the entire service manual? Are these available for sale somewhere?
- Jay
   / Remove LT1050 steering sector #4
Jay - that's a section from the cub cadet 1000_1500 series repair manual that I was able to download at no cost from PDF Manual Web Archive . You'll need the FULL model number and serial number off the ID plate on your machine (prolly located in the cavity under your tilting seat) to access the site. One caveat - I got my d/l some time back - it may or may not be available now.
Thanks again. Only the Owner's Manual and Engine User's Manual are available there for mine.
- Jay
   / Remove LT1050 steering sector #6
jay - sent you a PM
   / Remove LT1050 steering sector #7
I appreciate this post. I downloaded some good info on my mower.
   / Remove LT1050 steering sector #8
glad it helped :)
Zero Turn Mower (A48082)
Zero Turn Mower...
2019 CHEVY 5500 CAB CHASSIS (A50505)
2019 CHEVY 5500...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
