remove install 914 A mower deck
   / remove install 914 A mower deck #1
leopard
New Holland 1220
Hey guy's I'm new to the tractor community
have a New Holland 1220 with a 914 A mower deck. I'm ready to remove mower deck for the winter due to install rear snow plow. Need some advice where to disconnect the PTO what side.
Thanks,
Leopard
   / remove install 914 A mower deck #2
Welcome to TBN. :)
   / remove install 914 A mower deck #3
Where the mower pto is connected up at the tractor, there is a ring around the pto, grasp it and pull forward. Your pto shaft should slide forward off the spline. It's easiest if you have no implement on the 3pt at this time so you can lower your mower all the way. Pull your 4 pins to disconnect your mower from the tractor. At this point, I raise the front tires off the ground with the loader(if it's on) or use my high lift jack that way the deck has more room to slide out either side.
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2021 FREIGHTLINER...
1998 Ford F800 2,000 Gallon Water Truck (A49461)
1998 Ford F800...
