Mowing remove blades
   / remove blades #1
cutter49
Conroe,TX
JD ZTRAK 915
What size wrench do I use to remove the blades?
   / remove blades #2
Pretty sure 30mm.
   / remove blades #3
I clicked on this thread to see what blades he was talking about and you already have it figured out and offered the socket size!!! You are on the ball today Larry!!!! :D
   / remove blades #4
Yeah, but is the OP asking about a MMM, Bush Hog type, flail (not likely), sickle, or (I'm out of ideas)? :)
   / remove blades #5
I trust my friend Larry's intuition..... I'm betting MMM. :)
   / remove blades #7
His info shows he has a BX1870, so my info was based on this. You can also do the change with n SAE, but it is an odd size and the fit is not quite as good.
   / remove blades #9
my answer would have been 'the size that fits'... but that's just me.
I usually just go to the tool box and grab a couple wrenches or sockets that look close, and use the one that fits.
Pete
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
Bell B30E (A50123)
Bell B30E (A50123)
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
2016 Nissan Titan XD SL 4x4 Pickup Truck (A51692)
2016 Nissan Titan...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
