Removal of exhaust pipe on JD 6 series
   / Removal of exhaust pipe on JD 6 series #1
paulgc
JD 6105D, JD 2240
Hello:
I am trying to remove the exhaust pipe on a 2014 JD 6105D. I need to do this in order to get access to the open crankcase ventilation (OCV) filter. One of the bolts of the bracket that holds the OCV filter housing is difficult to get to - I could not remove it even using a flex extension.
Please see attached figure. I plan on removing the three bolts 1 and I wonder if I should also remove the heat shield 5 in order to get to clamp 10 or if the exhaust pipe 8 will come out of pipe 9 without removing clamp 10. I am asking this because I cannot tell from the figure what clamp 10 is holding on.
I would appreciate any help I could get.
Thank you,
Paul
   / Removal of exhaust pipe on JD 6 series #2
The clamp is only holding the funnel shaped adapter onto the exhaust filter assembly. The exhaust pipe will come off by removing the 3, #1 bolts. The funnel shaped part directs the flow of exhaust into the pipe with actually touching it.
Thank you - I will do it and report back.
Paul
I finally changed the filter. I was not able to remove the exhaust pipe. After removing the three bolts 1, I could not pull the exhaust pipe out - I am not a strong guy. However, I removed the two bolts 2, and that gave me enough space to access the bolt of the bracket. The OCV filter was soaked in oil and I had a little bit of oil in the filter housing.
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
UNUSED CFG QH12R EXCAVATOR (A51247)
UNUSED CFG QH12R...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2021 JOHN DEERE 8R340 LOT NUMBER 136 (A53084)
2021 JOHN DEERE...
HYD PUMP & TANK SET (A51248)
HYD PUMP & TANK...
2023 UNVERFERTH 632 LOT NUMBER 147 (A53084)
2023 UNVERFERTH...
