Removal of Bobcat 743 engine
   / Removal of Bobcat 743 engine #1
bratvold
Corcoran,mn
Bobcat 743
I have a hydraulic leak that I've been told is servicable only by taking out the engine and replacing some oil lines. I've swapped auto engines and transmissions before but never on a diesel Bobcat. Can anyone point me to any reference material that might be out there or share any do's and don't you may have yourself learned when pulling a Bobcat engine? Thanks in advance. Greg.
   / Removal of Bobcat 743 engine #2
I am in the same boat as you. Getting ready to pull my engne to do the same. If you provide your e-mail, I will try and send you an electronic copy of the shop manual.
Thanks so much! My email is bratvold@comcast.net
I've read on other sites that the engine removal is pretty simple. I might start to tear into it by middle of next week. Why are you taking your engine out?
Thanks again. Greg Bratvold. (Minneapolis,MN)
   / Removal of Bobcat 743 engine #4
A bad leak. I thought it was the hose which has the nut between the bottom of the loader pump bay and what looks like a control valve. No way to get to it without pulling the motor and pump. Trying to send the file. It is a little too large. I will figure a way though.
A bad leak. I thought it was the hose which has the nut between the bottom of the loader pump bayand what looks like a control valve. No way to get to it without pulling the moter and pump. Trying to send the file. It is a little too large. I will figure a way though.
Per sending a large attachment...............
Send me just a quick note without the attachment so at least I have your direct email.
My family and I have been using 'dropbox' for sharing large video files between family members. It's free and worth a look. >Greg.
   / Removal of Bobcat 743 engine #6
You should have it Greg. Thanks for the dropbox tip. Worked great!
   / Removal of Bobcat 743 engine #7
Sorry for the typos. I corrected them in my original post.
2000 Nabors 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 40 Ton...
FOREST CITY 13' CHOPPER (A52708)
FOREST CITY 13'...
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
KBH 25T Tender (A56435)
KBH 25T Tender...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
