Oil & Fuel Removal Injector Pump on 245 Massey ferguson
   / Removal Injector Pump on 245 Massey ferguson #2
The cover in front of the injection pump needs to be removed for three gear to hub bolts. After these are out shut off fuel and remove lines as needed, and throttle and stop linkage also. Check where pump scribe line is now, make a note whether it lines up with line on case. Then remove the three stud nuts that hold pump to case and remove pump. This pump can't be put back on wrong as drive gear has a pin that enters a notch on drive hub. What trouble are you having, I have repaired pumps since 1976. May be able to help, have had a pump even mailed from Canada, California, and several other states.
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
1986 Wisconsin 24' Tilt Deck Trailer (A52384)
1986 Wisconsin 24'...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
(4) 64" X 40" ALUMINUM POP-UP SIDE WINDOWS (A51248)
(4) 64" X 40"...
2024 Polaris General XP 1000 Premium  (A52384)
2024 Polaris...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
