Removable pickup box.
   / Removable pickup box. #11
On my last two trucks I had bed boxes.
I don't want to drill into the bed or bed rails.
I always get a plastic bed liner for the truck. A bed liner that has notches in the side to hold 2x lumber. So what I did is buy some PT lumber and cut it to fit the the bed liner notches. The bed liners I have had all had notches in front of the rear wheel well. I cut the PT wood to fit across the truck bed and then I put in blocks of wood as needed to keep the bed box from moving fore/aft and side to side.
Cheap. Fast. It worked. And removable.
The across the bed PT 2x was high enough so that I could slide material under the bed box.
When I sold my old Chevy I just took out the box before I sold the truck. Nobody knew it was there. Once our house was build on our land I took out the bed box from the truck so I could haul more stuff in the bed.
I might have had $20 worth of PT in my solution. :D Twas not pretty but it worked.
Later,
Dan
   / Removable pickup box. #12
N80,
Why not make your own rails or purchase the aluminum rail with a slot. and cut/make the Teflon sliders to bolt on your box, and slide in the rails. You should be able to loosen the knobs on the inside of your box and slide wherever. If you want to really get slick, install double screw rails driven by a 12v DC motor to move your box front to back or in between. Similar to the threaded rods to move electric seats fwd and back.
   / Removable pickup box. #13
The second box the OP showed are quite common. They are a hassle to get things into and out of if your short or the truck is high. If both apply its even worse.:(
There are full box length tool boxes that fit on the side and extend above the box rail but do not reach down to the box floor. These are much handier but may not take as large an object.:D
AZ Truck Accessories | Weather Guard Aluminum Lo-Side Boxes
   / Removable pickup box. #14
TallyHo...I have also seen the windows that open out on the sides of a topper. It sure does make it easier to get stuff inside. I may go that route next time.
   / Removable pickup box. #15
I have my toolbox (across the bed) held down with "nutzerks". They're like rivets but with threads inside. They install just like rivets. I drilled 4 holes into bed rail to match toolbox factory holes, remove toolbox, then drilled to the correct size for the 4 nutzerts. Now, this method does require me to remove 4 bolts for removal, but my tools are in the toolbox anyways. Not a big deal. Cheap and easy, but does leave 4 threaded holes in your pickup's bed rail. It might be an option to consider.
   / Removable pickup box. #16
I have the trac rack system. Crazy expensive, but its probably worth it. Be tough to build your own for less. You can buy the rails separately if you want.
The sliding box/rails are really nice though. And though I bought the adapters to fit other boxes on there, I ended up buying the track rack box. It just works nicer. Wait till you see what they charge for it!
Just about every contractor up here has a trac rack though.
   / Removable pickup box. #17
This may or may not apply to your application but I'll throw it out there for everyones "mulling". At one time I was in the garage door business and we would from time to time use rollers and track to fabricate rolling trays and such. I don't have any pics but we mounted our track to the inside of the side boxes of our topper. We fabricated a "tray" to store our springs on and mounted the rollers to the bottom of the tray. By installing the rollers in the track, this tray could roll front to rear so we could easily grab the springs off of the tray and roll it back to the front and lock it in place with a standard sliding lock you find on most residential doors. To keep the tray from coming too far out the rear (tailgate end) we put in a bolt and nut to serve as a positive stop. This worked really well but keep in mind we were using small pickups so the reach wasn't too far. This "theory" or design might be something some of you comrades out in TBN land might be able to apply somewhere.:D
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
UNUSED TELESCOPIC LADDER - 2.5M+2.5M (A54757)
UNUSED TELESCOPIC...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2015 Ford F-150 Pickup Truck, VIN # 1FTEW1EFXFFA41510 (A54865)
2015 Ford F-150...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
2007 Mazda CX-9 AWD SUV (A55758)
2007 Mazda CX-9...
