REMOTES
/ REMOTES #1
Bob77064
Elite Member
KY @ TN line
2011 LS R3039
How important are rear remotes? Can the side remotes for the FEL be used as a front remote?
/ REMOTES #2
Depends.....you can use the remotes to the FEL if you don't need to use the FEL. But if you plan is to use an additional hydraulic cylinder such as on a grapple.......there pretty darn inportant.
Stay Classy
/ REMOTES #4
When I bought Massey 231s I had 1 rear remote installed. At the time we were still cleaning up the property and was using a 4xd dump wagon quite a bit. I still use it for hauling fire wood out of the woods. I has also come in handy with chute on my snow blower.
/ REMOTES #5
I have triple rear remotes on my 2008 Mahindra 5525.
For front mounted equipment, I run a pair of 3/8" hyraulic hoses from the rear remotes forward.
/ REMOTES #7
The setup on your Mahindra looks like a bit of home brew. Very tidy. Tell me what you have done there. At some point I would like to add a rear remote or two, but have been a bit put off by the price of the New Holland kit. I have a diverter valve on the FEL, and have been using those lines as needed.
Thanks,
Christopher
/ REMOTES #8
Thanks,
Christopher
Home brew--no way. That's a dealer installed setup ($700, installed when I bought that 2008 Mahindra 5525 new). It's his own design, not factory. The power beyond (PB) port on FEL control block is used to supply high pressure to the triple remote valve. And the spent fluid is returned to the sump via a tee in the return line.
/ REMOTES #9
The dealer did a nice job with your setup. By home brew I was thinking ,"not factory".
I will think about how that setup might work for me. Thanks.
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2014 Lincoln MKS Sedan (A61574)
2014 Lincoln MKS...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
Mini rock grapples (A61567)
Mini rock grapples...
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2022 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2022 FREIGHTLINER...
