Remote Valves: what type do I need?
/ Remote Valves: what type do I need? #1
KTM300
Arkansas
Kubota B3030
I am looking into the options for rear remotes on a B3030. I've read much about different types of valves so I want to make sure I don't get the wrong set-up, or end up with a system that will not allow me to operate different types of implements.
I understand, I think, that for a TnT I would want 2 double-action (DA)valves. I believe these will have to be open center. Is that correct? These type of valves could then be used for any implement that used double-action cylinders.
However, how would that work if I had an implement that required a pressure supply? For instance, I'm thinking there may be a 3PH wood splitter in my future. Wouldn't this require hydraulic pressure and use it's own valve for cylinder actuation (or do they always use a PTO-driven pump and separate hydraulic system)? How could I make use of the rear remotes to operate the log splitter if the valves are both for DA cylinders?
What other kinds of valves are commonly used? I see many different descriptions in the Surplus Center catalog but am unfamiliar with the terminology.
I appreciate any and all comments.
KTM300
/ Remote Valves: what type do I need? #2
The Prince stack valves are very popular for your application.
Basically you want:
4-way
Double acting
Spring return to center
Adjustable relief valve
Power Beyond capable
Open Center
As for the splitter, a popular way to power it from remotes is to bungee the handle down so the fluid flows continuously through the valve on the splitter.
You can do a search here for "prince" to see how other's have done it.
2020 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2020 FORD F-150 XL...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab Pickup Truck (A59230)
2018 Chevrolet...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
