Remote Valve Body leak
/ Remote Valve Body leak #1
valley
Platinum Member
mountain valley near Tahoe
Michigan 55A, Foton 254
Greetings, This valve is on the deck, on skiers right between seat and fender.
The valve is three blocks with two through bolts. There is a leak between the blocks.
Question are they sealed with Orings or rubber clad metal washers or?
If you've had one of these apart, let me know what you found so I can have the nessary on hand before removing. Thankyou
Richard
Here are a couple of pictures. This is on a Foton 254.
/ Remote Valve Body leak #3
All of the valve stacks I've ever had apart were all sealed with O-rings.
Excuse my ignorance but what is a "skier" in your vernacular?
I'm a skier but I don't understand the correlation.:confused:
/ Remote Valve Body leak #5
Yep, probably O rings. Just take it apart and take a sample to the local hydraulic shop...
Thanks, This leaks enough to be messy. I've been putting it of for too long.
I appreciate the help. Thanks again. Richard
Thankyou for the help.
I disassembled the valve and replaced the Orings, 12 of them. Thanks again.
Richard
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2001 VERMEER E550 VACUUM (A60736)
2001 VERMEER E550...
2019 John Deere 344L Articulated Wheel Loader (A60352)
2019 John Deere...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
