Remote Valve Body leak
/ Remote Valve Body leak #1
valley
mountain valley near Tahoe
Michigan 55A, Foton 254
Greetings, This valve is on the deck, on skiers right between seat and fender.
The valve is three blocks with two through bolts. There is a leak between the blocks.
Question are they sealed with Orings or rubber clad metal washers or?
If you've had one of these apart, let me know what you found so I can have the nessary on hand before removing. Thankyou
Richard
Here are a couple of pictures. This is on a Foton 254.
/ Remote Valve Body leak #3
All of the valve stacks I've ever had apart were all sealed with O-rings.
Excuse my ignorance but what is a "skier" in your vernacular?
I'm a skier but I don't understand the correlation.:confused:
/ Remote Valve Body leak #5
Yep, probably O rings. Just take it apart and take a sample to the local hydraulic shop...
Thanks, This leaks enough to be messy. I've been putting it of for too long.
I appreciate the help. Thanks again. Richard
Thankyou for the help.
I disassembled the valve and replaced the Orings, 12 of them. Thanks again.
Richard
2014 GENIE GTH1056 TELESCOPIC FORKLIFT (A62129)
2014 GENIE GTH1056...
2017 Ford F-550 Ext. Cab Enclosed Service Truck (A61568)
2017 Ford F-550...
2011 Ford F-250 Knapheide Service Truck (A61568)
2011 Ford F-250...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
2020 Deere 544L (A60462)
2020 Deere 544L...
2014 POLAR TANK CRUDE TRAILER (A60736)
2014 POLAR TANK...
