Remote operated log splitter
   / Remote operated log splitter #1
bh3zfc
ALABAMA
JD 5045E
Used a 3pt log splitter last week and on this model tractor the remote hyd lever had to be tied with a strap so that the log splitter would operate. Will this cause damage to the tractor?
   / Remote operated log splitter #2
No that won't affect hyd system
   / Remote operated log splitter #3
Just be sure the control valve on the splitter is open center to match the tractor hydraulic system. If you run closed center valve on open center tractor, the hydraulics will overheat and can cause damage to pump and seals.
   / Remote operated log splitter #4
Good point jd110. I didn't consider LS valve being closed center type since a larger majority of hyd valves are open center.
Surely if it is a new log splitter that was built for this type of hook up it will be a open center valve.
Should it say this somewhere on the valve or is there a way to tell?
   / Remote operated log splitter #6
When you tie the tractor lever back, you shouldn't hear any hydraulic hissing sound or the engine shouldn't labor. If it does, then chances are good it is closed center.
   / Remote operated log splitter #7
So how do you determine the open/closed type on a Kabota 4400 HST if you're somehow tapping the system for remote use of a DR 3PT log splitter mounted off the tractor stationary on the ground? Thx.
   / Remote operated log splitter #8
The Hydraulics:
Type: open center
Capacity: 10.6 gal [40.1 L] (gear)
11.9 gal [45.0 L] (hydro)
Valves: 0 to 3
Pump flow: 8.4 gpm [31.8 lpm]
Total flow: 13.5 gpm [51.1 lpm]
Steering flow: 5.1 gpm [19.3 lpm]
The tractor is open center as you can see, The pump flow is 8.4 GPM's
Make your self a remote QD hose for a log splitter log/ BH connection. Run a hose from the loader valve PB port and put a QD on the end, then plug in the log splitter and run a hose from the log splitter valve back to a return line of dump to tank.
   / Remote operated log splitter #9
Hooked my splitter supply line into the pressure port side of the BH connection on the tractor. Hooked the BH supply line into the return on the splitter. WORKING LIKE A CHAMP! HAPPY! HAPPY! HAPPY!
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53473)
2015 Ford F550...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2016 Bobcat E85 Midi Excavator (A51691)
2016 Bobcat E85...
