Remote Hydraulics Install
/ Remote Hydraulics Install #21
Have you ever noticed though the prices at Northern Tool ( supplier of Chief) for the same size and stroke cylinders from various manufactuers varies, sometimes by alot. I have purchased various cylinders from Northern and given the application they worked great. I can see a difference in the quality though between them and the Gannon or Gilmore. Nothing wrong though in going with them, its a great way to save some money. The factory kits will add alot of extra cost but the setup is much cleaner then most folks could do themselves. Rat...
/ Remote Hydraulics Install #22
Crystal Clear! See attachment please.
Thanks,
Jim
/ Remote Hydraulics Install #23
You are correct, Rat. Knowing what you have and what you need to get the job completed are key issues. Here is a photo of my toplink installed. It fits perfectly with the NH remotes. I'm pretty proud of my $178 setup. It should be noted that my cost did not include the remote control, only the cylinder. New Holland gets about $300 for the first set of remotes and about $200 each for the next two sets. Next year, I think I'll add the two remaining valves and then put a tilt cylinder on too.
JimI<P ID="edit"><FONT SIZE=-1>Edited by jinman on 12/12/01 09:41 PM (server time).</FONT></P>
/ Remote Hydraulics Install #25
JimI,
Can you give me the model# for the Chief toplink cylinder you purchased? Did you buy this from Nothern? Your cylinder has a 10" throw, but how long is it? TIA
/ Remote Hydraulics Install #26
My cylinder is a 2510TCTL and you can see the details at the following link: http://www.baileynet.com/baileynet/productBrowse.asp?sku=214995+++++++
BaileyNet is a wholesale supplier, but they sold me the cylinder. They have many more to choose from. It would be better if it were 1-1/2" shorter, but I can modify it pretty easily if it ever becomes a real problem. For now it works just fine.
JimI<P ID="edit"><FONT SIZE=-1>Edited by jinman on 12/14/01 01:53 PM (server time).</FONT></P>
/ Remote Hydraulics Install #27
Ok Jim, you have my intrest on that chief cylinder. Did you have to do anything special to buy it from baileynet? And does the cyl. still work good on your TC.?
Kevin
/ Remote Hydraulics Install #28
Kevin, the cylinder works very good, but the length is about 1-1/2" longer than a normal toplink when it is adjusted to its shortest length. I had to grind down the Category 2 fittings in width and buy category 2 to category 1 adapter bushings at Tractor Supply. Check out my previous posts about fittings and hoses needed to complete the job. It's actuallly all very easy to do. If I ever need a slightly shorter toplink, I may just modify the plate on my tractor by adding new holes for the toplink to attach. I just registered with baileynet and ordered the cylinder. It showed up in only a couple of days. Be sure to give them a fax number so they can fax you a copy of your "paid" invoice if you pay with a credit card. That's all there is to it.
JimI
/ Remote Hydraulics Install #29
I'm considering just adding one control valve and using it primarily for a top link cylinder and occasionally for a side link cylinder.
When you said
"I had no idea the top link cylinders were so expensive. Here's exactly what I received for $1000.... Two rear remote kits, a top link cylinder, and a side link cylinder. "
does that mean there is a difference between the top link cylinder and the side link cylinder or can I use the same one in either place? For example, if I have one control valve I would normally use it to run a top link cylinder for my rear scoop. But, on occasion I would want to use the same control valve to run a side link cylinder when using my grader blade or plowing the garden, so I would want to remove the top link cylinder and put the solid top link back on, then remove the side link and replace it with a side link cylinder. Obviously it would be better to have both, but I’m trying to figure out a way to get by with just one control valve. I very rarely use a box blade, so it’s not worth the cost for me to have both.
/ Remote Hydraulics Install #30
Yes, Danny, you can do what you're talking about with the hydraulic cylinders. It's a bit time consuming to be swapping them out, but I think your question is only whether the same valve will work OK with either cylinder and the answer is Yes. The only difference in the cylinders (in my case at least) is the length of the stroke.
/ Remote Hydraulics Install #31
I just called my dealer and was quoted $253 for the first remote control valve kit and $213 for the second one. Labor to install would be $45/hr and they said it would take about 1 1/2 hrs to install, so about $70. I didn't ask about the price of the cylinders yet. They're having a 10% off sale tomorrow, so I may just get it the valve kits and then shop around for cylinders. I'll install it myself though. $70 isn't bad, but I'll also have to pay for them to come out to my house, which would be about another $75, and that's outrageous for a 40 mile round trip!
/ Remote Hydraulics Install #32
That is a good price for the valve assembly. Most of the dealers are asking $400 now due a NH "price increase". You better get it now. I bought one from a dealer that had not raised the price yet also. They charged me 1 hr ($35) for the install while doing some other work. I am still looking for the perfect cylinder for the toplink... I will probably have it made.
/ Remote Hydraulics Install #33
I dont know what dealer is telling you there has been a price increase on the tc tractor valves. I can tell you for sure there has not been they still list for about 250.00. sounds like your dealer is taking advantage.
/ Remote Hydraulics Install #34
I ended up having the dealer install mine. Due to a deal I worked out for some warranty work, I didn't have pay for the transportation (it's a long story, see TC29D rear PTO lever moves). Anyway, I just thought I'd let everyone know that it took them 2 1/2 hours at $45/hour. The mechanic said it was the second one he installed and couldn't pick daisies to get it done in that much time. It sure is a nice setup! The tractor looks more complete now that there are levers in those slots.
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2017 Nissan Sentra SR Sedan (A61574)
2017 Nissan Sentra...
Volvo EC220EL (A60462)
