Remote hydraulic fittings leaking
   / Remote hydraulic fittings leaking #1
Matune
Chewelah
2020 TYM 474
My 474 hydraulic remote above the PTO is leaking oil. The o ring connection leaks because the o ring does not stay in the seat when tightening it down.
is the o ring bad? Is there a better style available?
   / Remote hydraulic fittings leaking #2
If the O ring does not stay seated and you have tightened it - O ring is probably damaged by now. Try with a new O ring.
   / Remote hydraulic fittings leaking #3
O-rings can swell if exposed to the wrong fluids for the “rubber” type. someone may have installed the wrong o-rings in the past, and they will not go back into the grooves. I play with enough esoteric stuff, that I bought o-ring kits in imperial and metric from NAPA. With those I can get really close, and they are rated for just about every fluid you will come up against in engines and hydraulics.
Thank you! It’s a new tractor…well, a year old now with 250 hours. It just started leaking and I noticed the o ring had burped out. I put a new o ring in and it still burped out a bit.
I’ll go to the hydraulic hose store near me and get them to size it for me.
thanks folks!
I installed new o rings and it still leaked. Put in one of those washers with an o ring inside it and it sealed up. Had to use both though. O ring and the o ring with a washer.
dealer suggested that using the loader hydraulics at the same time as the remote will cause it to burp those o rings out….
   / Remote hydraulic fittings leaking #6
Are you sure that maybe you don't have a small tiny crack in the fitting?
maybe just swap o rings from a different connection and see if the problem follows the suspect o ring.
I’m actually not sure about that! I can not see anything but the top link hit the coupling sleeve and disconnected the hydraulic hose. Wish it was a bit further away from the top link!
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
378811 (A51573)
378811 (A51573)
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
CAT Skid Steer (A50322)
CAT Skid Steer...
