Remote auxiliary hydraulics for International 444
   / Remote auxiliary hydraulics for International 444 #1
Stephen humphrys
Fergurson
I want to add a rear hydraulic valve and outlet to the rear of my 444 international tractor. The tractor has factory 3-point, hydraulic power steering, but no auxillary valve. At one time there was a kit that would make this possible, but it is an obsolete part from international and no longer available. Is there a way to plumb into the existing hyd lines, add simply add a valve? If so, which line would be tapped into and how is it identified<
   / Remote auxiliary hydraulics for International 444 #2
You need a open center valve with power beyond and connect it before the three point valve under the seat.
The steel pressure line coming from the hydraulic pump that where the supplies the three point.
The power beyond port will supply hydraulic fluid to the three point valve.
   / Remote auxiliary hydraulics for International 444 #3
Here are two in salvage yards that appear to have the optional kit on them when posted. 19in all 444's but some don't have pictures. You might luck out and they are still with the tractor. Tough to beat OEM parts. If not, you can post a "want to buy" ad there. Look at top right of page in the menu. I've found more than several hard to find parts using this feature. One was a set up for dual remotes for my Farmall 656. Vendors have always contacted me within 36 hrs. and was always very satisfied with my parts. With today's technology a vendor can take a picture with their phone, and text you a pic of the part so you're buying a pig in a poke.
   / Remote auxiliary hydraulics for International 444 #4
The original poster doesn't indicate his location but one has to be careful with the model numbers of these IH tractors. A U.S. market 354 is the same as a 444 in Canada and the rest of the world. A Canadian market 444 is a smaller tractor than the American 444.
Many Thanks
dieselscout80
   / Remote auxiliary hydraulics for International 444 #6
   / Remote auxiliary hydraulics for International 444 #7
I’ve wanted to do it to my IH 424.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
Caterpillar Loader Quick Coupler (A53472)
Caterpillar Loader...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
