Relieving hydraulic pressure
   / Relieving hydraulic pressure #1
jcummins
Veteran Member
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I learned sometime back to kill the tractor and cycle the loader/3rd function/diverter thru it's paces to relieve pressure. Many years ago when I had not learned that, taking the male end and slamming it hard against a flat surface took care of the pressure.
Yesterday went to hookup grapple, and one line on the grapple had pressure built up in it. I'm near 100% certain I went thru the pressure relieve process, but in any event, the pressure was there. No amount of slamming the connector, even rapping with a hammer, etc would budge the ball on the quick connect. I finally had to take the end connector off to get rid of it.
My question is ..... does a tool of sorts exist to relieve this pressure when it does occur, for whatever reason, without taking the hose apart?
   / Relieving hydraulic pressure #3
With what we sell when you take off something in the cold and then attempt to reattach in warm weather it can be quite a problem!
2006 CMI C125-1 Ride-On Forestry Mulcher (A49461)
2006 CMI C125-1...
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
1992 GROVE AP-308 CRANE (A51222)
1992 GROVE AP-308...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
