Relief Valve
/ Relief Valve #1
rock2610D
Cheyenne WY
2610D
Could someone tell me where this is located? I have be advised that I could have a malfunctioning one.
I have a clicking/thumping sound when raising loader and curling bucket. No clicking sound when lowering bucket or uncurling bucket. Also happens when raising 3pt.
Thanks
Rock
/ Relief Valve #2
If I'm not mistaken,( & that's possible) it's inside the hyd pump itself
/ Relief Valve
Looked at my pump info in my manual and there is nothing to suggest a relief valve on or in pump.
I did find some other relief valves but am not sure they are what I am looking for.
1st is on gadget that has the stop valve on it under seat. Its called a main system relief valve.
2nd is whats called a rock shaft relief valve and its also on the gadget under the seat.
Could one of these cause the noise I hear??
/ Relief Valve #4
There is one inside your loader valve & one inside the 3pt valve. Send me an email & I'll send you some pictures of where it is at.
The loader & 3pt hitch use a separate relief valve. I doubt the clicking in both the loader & 3pt are because of that. It sounds to me like it could be something slipping in your pump drive system when under a load. We have seen several times where a key or the coupler get stripped and start to slip when the hydraulic system gets pressured up and the pump gets hard to turn. It make sort of a clicking sound. Can you tell where the sound is coming from?
Just a thought.
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ Relief Valve
Sound is definately coming from the right hand front part of the engine. Where the pump is.
Sound is still there even when the loader is disconnected. Its a Allied loader and loader controll has a bypass system so it can be disconnected and not dead head pump.
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A66738)
2019 Mercedes-Benz...
Generator (A64553)
Generator (A64553)
PORTA POTTY (A67714)
T/A Dovetail Flatbed Equipment Trailer (A66736)
T/A Dovetail...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
